Help NFC - In the Battery
I am sure many know that this phone and clearly the battery are very interrelated when it comes to battery and the NFC chip.
I clearly need to look into how this tech works more but I should assume and to those who already have purchased the extended battery - is the extended battery also coming with the NFC option embedded into it?
I would hope...
If you have not seen this just read the case of the battery...
yes the extended battery has it.
the NFC that the battery is pertaining to is the NFC Antenna that it houses under the label/wrapper of the battery.
Yup it comes with it, I have used the extended battery while making a google wallet purchase with excellent results.
