Hello all, I just recently rooted my Incredible, and am still working to find just the right ROM. I installed Nils Business Gingersense with Sense 2.1/3.0 not realizing that a 3.0 and 3.5 versions was out. I cannot find a definitive list of differences between the three versions. The first doesn't seem to be full 3.0, just 2.1 with some elements of 3.0.
Is it worth my time to switch to another version, or are there not any major changes? If I should, which version is better in terms of stability as well as battery life? Also, based on his instructions, I cannot do an upgrade to my current version, correct?
Also, one other question in terms of ROMing, when I installed this version I backed up my apps using Titanium. As I reinstalled, I had to manually allow it to install each app. Is there a way to automate this?
Thanks,
Brennan
Thanks,
Brennan
