When you flash a new ROM it's a good idea to boot into your recovery then wipe the cache, wipe data, and factory reset. It's a good idea to do this a 2-3 times.
Also make sure you are using the clockwordmod recovery 3.0.0.8/7 which is required to flash the ROM. Also you need the correct Radio and hboot to flash it otherwise it won't work.
So don't do a titanium backup just wipe and reflash and redo titanium backup after flashing again.
