Root Ninja Morph issue
ECFfighter7232
Android Expert
ok, so maybe im having a brain fart and cant remember a step im missing.
I'm trying to replace an image in the framework. I have the new image I want on my sd card in a folder called "theme" and it is a .png image.
I go into ninjamorph, newproject>system>framework>framework-res.apk>res>drawable-hdpi>scroll to the image I want to replace and select it.
it says select the image you want to replace it with and sends me to my sd card
I go to my theme folder, and theres no images there... the .png doesnt show up.
I have also tried putting it in my galley, root of the sd card, several places. and none of them show up... I dont get it... did I miss a step somewhere?
Ive done it before but its been a while so maybe im forgetting something?
thanks for any help
(oh and to add to the confusion, three other .png images I have in there do show up, just not the ones im trying to swap.)
edit: only difference I can see between the .png's im trying to use and .png images that do show up, it that the ones that show up are ".png" and the ones that are not showing up are ".PNG" I dont see why caps would make a difference, and I cant seem to get them to not be caps...
thanks for any help
It must have something to do with the caps, I've used it several times and I can't see where you're missing a step or anything.
yeah thats exactly what it was. I wound up finding the image with png in lower case and it worked and showed right up.
one odd thing to note, when changing .PNG to .png in root explorer, it shows that it saves it right, but as soon as you back out and go back into that file, it was back to caps again... maybe I just had a weird file lol.
thanks for the help and look airmaxx
