Help No 3G at all
Mac171
I'm on Orange and 3G does not work at all, I have turned it on and off through the settings, and even factory reset the phone, yet the only time i can connect to the net is through Wi-Fi..
Any help will be greatly appreciated.
-Mac
Don't do anything drastic. Had same problem and phoned Oreange customer service. It turns out that they are doing "routine maintenace" on their mast local to me. Same could be in your area. Mine has come back on a couple of hours later.
P.S. 2G worked fine.
Its been like this for a week now, although speaking to Orange is a good idea.
It just dawned on me. Have you set up the APN (Access Point Name) under settings > Wireless & networks > Mobile networks > Access Point Names - there should be one listed @Orange internet'? Sorry to state the obvious but it happenmed to me a vbiew times that, for whatever reason, the Orange network did not push the settings to my phone after I'd inserted the SIM card. If you don't have anything listed under APN then you need to do this manually (you'll find the required settings by googling 'Orange settings'. Again, sorry if I've stated the obvious, but other than that you should not have a problem. If you still do then contact your hardware manufacturer (don't waste your time with Orange).
