i can no longer get 3g with a ST sim card... its rooted and flashed a couple roms on it sim card has been unlocked 3g use to work but after flashing a rom i no longer have 3g
There are several CM9 ROMs. I think Aeroevan's has GSM working.
^^This^^
Do you know if your rom (which one are you on? Specifically.) supports gsm?
Come to think of it, I thought you couold only get 2g on global mode/gsm...
There's your problem. You can't have 3g on gsm. The phone itself doesn't support it. At least that is what I understand.
