Nice! Thank you! Simple and sweet and accurate.
I used this app on my HTC Thunderbolt but I do have a question about its use on the Razr. I don't recall if this happened on the T-Bolt or not...if I am running in CDMA auto (PRL) and at some point restart my Maxx, is it normal for the device to boot back up in LTE/CDMA/EvDo mode? I just want to make sure it's working properly on my device.
Try this
open dialer
enter
*#*#4636#*#*
pick phone options
scroll down to just under "set preferred network type"
press the triangle in the right corner
pick CDMA auto(PRL)
back out with the back key
You should now have 3G only service. If you check under
System settings
Wireless & networks
more
Mobile networks
none of the options will be selected
There is no need to redo this on restart or reboot, it will remain in 3G. If you want 3G/4G again just pick LTE/CDMA under settings.
