I installed the rooted leak 2.1 version a few months ago, and I didn't really notice anything, so I forgot about it. Recently (a few days ago) my phone was turning on extremely slow, so I did a factory reset. That cleared the load issue, then I had to call Verizon to manually program it so I could make and receive calls/text messages. I thought that cleared those issues, however, now 3G is not working...
This is getting really frustrating, and I have no idea how to fix this. I've pulled the battery, tried doing another factory reset, toggled network options, mobile switch widget, everything. No idea. Whenever I try holding the power button and up button for the reset now, it gives me a caution sign.
As you can tell, my phone is really acting up. I can't go to Verizon for help until I get the root off, which, to my knowledge, is currently impossible to remove the 2.1 leak.
Thank you in advance for help.
