Cooldude213
So I put music onto my lg esteem and when i play songs with accents like
So I put music onto my lg esteem and when i play songs with accents like ñ, ó, ect. it shows a diamond with a question mark. how can i fix that?![]()
they are clear and it still doesnt not work with the accents.That's weird , just check mines and it does shows accents and different word. Try clearing cache and data of music from application management at application settings.
they are clear and it still doesnt not work with the accents.![]()
spanish words like piWhat word does not shows its accent in music ?
spanish words like piña cariño afición ect.,,
yes i tried but it didnt for some reasonQuick note ; try unmounting and then mounting the sd card from settings > storage . do this first if not ;
Uhm. Yeah okay. Make sure that the title of the song is the same as the .mp3 name with its accents.
Do this, delete the song from the phone and try renaming the "title"(on windows, you name title by going property > details tab [I guess] and then in tittle you name it as supposed.) with its accent. Then transfer it back to your phone and restart the phone.
Nope nope regular font nor rom installedIt sounds like the font you're using doesn't recognize the accents. Do you have a custom font or ROM installed?
what do you mean?Maybe the ID3 tag is messed up in the song files?
what do you mean?
i do use it and it uses the name with the accent on both but my esteem doesnt show it tho.Every mp3 has space for data in the file that holds the displayed song name and artist and other info. If its in the file that info is displayed... if its not in the file then the file name is used. You can edit some of this info by right clicking the song in Windows, then Properties, then the Details tab.
how do you have both? and how do you change the system font?Check the language settings. Both Spanish and English. Or then change your system font to one that supports the symbols and accents character.
nopeDo you have rom toolbox?
Just tried searching Co
im talking about the music player
