So I tried to use adb on my laptop & it wouldn't work again, I checked my environmental variables & it hasn't changed so I don't know why, hell I just went through this a couple of weeks ago. If any can help me with this I'd really appreciate it.![]()
Ok well i'm pretty sure the triumph drivers are installed, USB debugging is turned on, on my phone, i've tried three different OEM cables they will connect it to my laptop via USB ? & finally commands i'm not sure anymore i can't remember, I've been staring at code & PNG's for too long lol. It's C:\ android-sdk-windows >cd ??
it's cd c:\android-sdk-windows if that is where it is located although it is probably cd c:\android-sdk-windows\platform-tools
When I did it I think I added both paths and it works good. Maybe try that?
Did you reboot your computer? That usually fixes the problem
