Root no android 1.0 device
syi
before we go any further i did a forum search, so theres that
when i go into device manager thers no android 1.0 device, the onlything with android on it is my actual phone and its only there when i plug in, when i tried to update the drivers for that from the specific folder that had teh drivers it said nothing new and i closed out and came here and did a forum search,.
any help is appreciated, please and thank you.
If it recognizes your phone, you should be good to go. Run unrevoked and plug your phone in as the Rooting Guide tells you too(debug on and charging). Unrevoked should pick it up and start when you click ok on the popup.
