No Bluetooth after update
nickstanley
Note 2 Verizon. Received my update but have not been able to connect to bluetooth in my car since. The one time I was able to, i had to go into settings and manually connect. Now, I don't even have that option. Any ideas?
Wait for the fix. Everyone gets different bugs with the 4.3 update.
Maybe they'll do KitKat right.
I wouldn't rely on a fix, whenever that's going to be released. It might fix one thing, and will break something else. The problem you described has been mentioned in different forums. I also had a lot of issues pairing up and controlling from my wireless headsets. The only solution - factory reset. I know it's painful to get everything back to the way it was before once you "reformat" everything, so make sure you back up. But I can tell you with 100% certainty - it fixed all my bt issues.
