cquinn
Well - managed to swap my handset out due to constant rebooting and since they had no refurbs available I got a new 0004. So rooted with unrevoked made a nandroid. Cleared data/dalvik and cache + Calkulin's FORMAT ALL. Reformatted sd card and flashed Myns RLS5. Updated PRI and prl. So far so good. Apps loaded one by one. Everything went sooth as silk. Went to sync bluetooth headset, which worked fine on all ROMs on 0003 and nothing. When I switch on bluetooth a listing for my headset appears under device name but it shouldn't be there as I haven't synced it to this device yet. Is it possible that I need to clear that setting for it to find my headset now? Do I need to revert my PRI / NV & can I do that safely with 0004? Used Wimax RSA key checker and my keys are intact.
Anything I might try to restore bluetooth?
Here's the rest:
baseband - 2.15.00.11.19
kernel - 2.6.32.17-gee557fd
htc-kernel@and18-2 #15
Build # - myns warm twopointtwo RLS5
Software # - 3.70.651.1
Browser - webkit 3.1
PRI - 1.90_003
PRL - 60677
Appreciate any help.
Here's the rest:
PRI - 1.90_003
PRL - 60677
