Help No Calls/Text
Majid
Hi
For some reason my S3 wont take make/take calls/texts...the weird thing is that it gets a 3G/H signal, and i can surf the net with it, but no 2G. Ive changed SIM cards and my SIM works, while putting another network SIM in my phone gives the same result. Even tried a Factory Reset and still no joy
Any ideas?
Majid
Am with Vodafone, they say its a problem with the phone, Im thinking hardware since a factory reset didnt help matters
Majid
Try Settings -> More (under Wireless and Networks) -> Mobile networks -> System select -> Automatic
Also, under Data Roaming, check the box if the above doesn't work
