Root No data connection or LTE on CM12/Candy? Try this!
When my phone starts I usually have a phone line signal, however my data is nowhere to be found. I did find a way around this (it could be a bit annoying if your phone resets as often as mine does)
1) Make a phone call (voicemail or test call are two I usually use) let the phone stay in call for 20-30 seconds
2) Open up the phone test menu (At the dialer type *#*#4636#*#*)
3) Go to phone information and turn the radio off then back on again
This has worked for me on every occasion that I have used it.
Good luck guys !
What about if I'm using ZV5 custom rom? I've tried everything that has been suggested and nothing. I even restored my stock backup, still no LTE and a very spotty 3g connection. I really have no clue what to do anymore. :/
Have you tried the auto activation?
Think its ##72786#
If that doesn't work, call your carrier and they can walk you through
this is great! haha Thanks! I really wanted to teather so i could play some gta online and it was only picking up 1x, thanks to this post I now have LTE
