Help no data connection
tudju
My data connection used to work well. But after quite some time with data connection disabled and some flights, I have not been able to switch the connection on again.
I played with the different switches (such as "enable data", "enable data when roaming", "use 2G only", "use wireless networks" for gps) with no success. I rebooted as well with no success. I tried to edit the APN configuration with some fresh data found on the internet. No more success.
I have unlimited data plan with my provider, even when roaming.
Finally, after a reboot today it works again. No clue why.
This is a big problem because the gps is not able to figure out the location without network access. I have not been able to get direction with my phone after landing twice.
Did anyone had the same problem?
