Root No Data On icarusmod-1.1
Kaze11
I Tryed reinstalling it and the same issue occurred. the 3g on top goes on in the beginning of the boot up then disappeares so i cant use the web. i cheacked my apn settings and there the way there supposed to be
cricKet
APN: wap.mycricket.com
Proxy: wap.mycricket.com
Port: 8080
Username: phonenumber@mycricket.com
Password: cricket
Server:
MMSC: http://mms.mycricket.com/servlets/mms
MMS Proxy:
MMS Port:
MCC: 310
MNC: 016
Authentication Type: CHAP
APN Type: *
is there something i did wrong?:confused:
Good to have you back,Kaze11!If you don't get a response soon,you may want to try re-posting your question in the sub-forum 'ASCEND-ALL THINGS ROOT' under the thread 'HOW TO INSTALL ICARUS 1.1' by Isaacj87.The members that hang out in that sub-forum are more likely to be able to help w/your 3G-ICARUS 1.1 installation issues.
cricKet
Port: 8080
Password: cricket
Server:
MMS Proxy:
MMS Port:
MCC: 310
MNC: 016
APN Type: *
I had to do this myself. Goto settings/wireless & network settings/mobile networks/access point names/ then select cricket. if it doesn't accept the first time, keep doing it. It should be fin.
OR
you might have to reflash Icarus.
