marefin
So after I updated by Captivate with the GPS "fix"
Samsung released I've run into this one very annoying issue. From time to time, I'll get this message pop up that says something like "update has been installed and ready to be used" (or something along those lines)
. Also, when I click on "Software Update" it says "No firmware". The phone works fine tho
. I check my About the Phone section and it says the firmware version is "2.1-update1"
. Anyone else having this issue or know how I can fix this. Also, my phone is rooted with OCLF. But I had unrooted the phone prior to the update. Any light on this issue would be significantly appreciated with a big thank you
(I like to use smileys a lot..........
edit. well it's not really a pop up. it's that message screen you get after you update the software. no clue what to call it.
)edit. well it's not really a pop up. it's that message screen you get after you update the software. no clue what to call it.
