no flash when browsing
sanity29
Not sure if its just me, but flash content doesnt show up when browsing. Is there a setting that needs to be turned on or off? If there is an update, how do i do so? For example adobe home page
Thanx
On side note: when I hit the pre installed google bookmark it brings me to a French version. I edited that bookmark but I just thought it was funny
Google being in another language is a known issue and happens even off of phones and has to do with bad geo-location data for the IPs involved. :)
You don't have flash. You have flash-lite which only works with some content (shockwave content doesn't work most of the time for instance) and only with content that is < version 9 of flash.
If you are using Fresh 1.1 then this is a known issue and there's an update for it you can find on Geek For Me – Android CDMA Sprint Hero.
Hopefully one of those answers your question.
I have a flashlight? Sweet. J/k. Sorry couldn't reset.
I read some where that it was a. lite version of flash. Just wanted to be sure that I wasn't over looking something. Or missed an update. Thanx for the reply
