Root No flash zip option?!?!
DaRayvn
im at the point where it says in the guide to select install.zip from sd card i select that but on the next screen the su file u need to flash isnt there...it goes to another screen that says choose zip from sdcard, apply/sdcard/update.zip, toggle signature verification, toggle script asserts, go back....those are the 5 options to choose from...
if i select choose zip from sdcard it brings me to another screen that has the options: android/ , lost.dir/ , rssreader/ , and su-2.3.6.3-efgh-signed.zip...
if i select the su file it brings me to another screen that says confirm install with a bunch of "no" options and a "yes" option next to the su file....
am i supposed to install that file??
Yes. That's the one.
