Help No GPS!
Hi all,
Tried using my newly downloaded co-pilot today but was unable to get a gps fix. GPS is turned on in the settings and mobile data is enabled but was unable to find a gps signal on an hours drive (luckily I had my stand alone unit with me!).
I also tried google navigation but was still trying to locate signals on the road back (still an hour drive).
Is this a common problem with the note? is there a fix?
The Note has one of the most sophisticated GPS receivers available - it works with the Russian as well as the US GPS constellations. Even inside my house I can get 7 satellites locked. So there is something wrong with your unit. Try the GPS Test app, free on the Play Store.
Ian
first time i have flashed ics from gb, it took couple of reboots and hours of waiting before the my note finds sattelites after that it only took 3-5 seconds.
