Help No Keyboard
mysta50
once again, got no reply to last thread. Don't even see last thread here.:confused:
I have an ascend phone and I have no keyboard at all. Want to install swype but cannot go to any sites on the phone since I cannot input any text. Help me Plz!!! also, how do I trnasfer files like Swype installer to my phone from my pc afterdownloading it to the pc?
Swype comes installed on the phone, unless you uninstalled it.
Try this. Open messaging (anything with an input box will do) and press and hold for a couple seconds on the input box. You will get a Select input box. Select Swype or whichever keyboard you wan to use.
NO, I didn't remove it and no choices come up when I keep pressing for keyboard choices. I'm totally lost here. Even tried to install Swype again and that didn't work either. What can I do people?????
go to settings/Language & keyboard and see if adroid keyboard or swype...
Swype is a little complicated to install. I can't really help with that. If you really don't have any keyboard at all on your phone, the first thing you should do is go to the market ON YOUR COMPUTER and download one of the free keyboards, then install it on your phone so you can at least use your phone, then go from there.
