Root No Live Wallpapers for CM7?
So I installed CM7 last night everything is running great!
I put the Live Wallpaper APKs on my SD Card and tried to install them via file manager and I get "Application not installed".
I also tried downloading Easy Installer from the market and installing that way but I ended up with the same results.
You need to copy it to /system/app
wet biker made a zip for this somewhere, but i can't find it... You can just use root explorer to do it tho
Thanks, i meant the one Wet Biker made with the theme chooser stuff already inside it... But that just a good :D
The themeinstaller.zip only has the theme chooser in it. I removed the live wallpapers a while back. I do have a live wallpaper zip floating around in here somewhere though, I think. Lemme see if I've still got it out there.
EDIT: YUP, here it is. Just flash in CWM and you'll be good2go.
CM7 live wallpapers installer.
http://www.mediafire.com/?3cuelokfeccp3ra
CM7Livewallpapers.zip
I'm late but thank you! :)
