Help No Lock No Longer Working
So I have poked through Google for a solution, though there have been a few updates since then so I figured I'd post anyway.
I have Juice Defender and No-Lock. I was reading about some incompatibilities between the two. I can't figure out how to get No-Lock working again. All screen controls are disabled in Juice Defender. Any ideas?
It did nothing the first time I clicked on the widget. After that it has worked flawlessly. I checked multiple times and turned it on and off several times as well.
I always do a reboot or reboot/battery pull (do pull when phone is powered up) after any software update.
Rebooted and pulled the battery...well, I knocked it off my table by accident, and the battery fell out. Still counts though.
Still not working though.
You may be right then about it being a Juice Defender problem as I don't have it installed. Maybe we can get some others to chime in that do have both installed.
For now I just remapped a volume button, but I'd rather get this working. I don't trust the buttons on the HTC phones.
So if anyone has ideas, let me know.
I did notice that the screen lock went back to the default 15 minutes, so they may have changed some of the code and broke no lock.
(Kind of funny--I set my screen lock to immediate. I have had a phone evaporate in an airport.)
Yep, it's still no working :-/. I feel like Juice Defender broke it.
Might have to switch back to SuperPower.
