Help No Lock Screen
Jbart15
Member
Before I updated to 2.2 I turned off the default lock screen and kept off through the update process and now with 2.2 there is no option to turn it back on only the pin, password and pattern options are available. Anyone have a suggestion as to how to get it back?
really? in security i have:
change lock pattern
require pattern
use visible pattern
use tactile feedback
set up sim card lock
visible passwords
install from sd card
set password
two greyed out options
clear storage
location is a seperate setting
use secure credentials
I was having the same confusion.
But the right answer is "Change Lock Pattern" which when I clicked that and saw a pattern screen I like some users mis-interpreted it as simply the beginning of a reset sequence, old, new, confirm new; not a re-confirm password before showing you a menu of things to do: None, Pattern, PIN, Password.
