rolltidedad
in a worse case,i believe you can run backup assistant. then you can go to verizons website and save the backup asst contacts as some kind of file,then import that file into your google account. i had to do that initially,when i first got my OG droid,as there was no other way![]()
the details are fuzzy now,but you could google "import backup assistant contacts to google" or somethin to that affect.
did you look at the other thread i linked? it mentioned an app you could possibly use to export them.
I like the VZW Back-Up Assistant idea and would like to give that a try. But something happened this morning that may throw a monkey wrench in the situation...
I used syncmypix yesterday (before I wrote this post) to see if it would fix the problem...it inserted 71 pictures but was unable to do anything with the remaining several hundred contacts. But this morning they suddenly appeared out of nowhere. But almost none of these newly-appeared contacts have phone numbers on them, only facebook names and e-mail addresses.
If I import all of my contacts from back-up assistant, and I have all of these contacts that suddenly appeared on my phone, I'm assuming that I'll have a bunch of duplicates and I'll have to figure-out a way to merge all of their data.
Unless...
If I imported contacts from Back-Up Assistant into google, would there then be a way to filter out any duplicates created from what's already on my phone and what I imported?
And by the way...here's one of the available export options from Back-Up Assistant: Export my contacts to an email service, such as Gmail, Yahoo Mail, etc.
