No more wakeup lag on my SGSII!
Since day one my Galaxy s2 had the notorious wakeup lag- it would take 1.5 secs or so for the screen to turn on after pressing the home or power button.
I don't know how many people have it, but it sounds pretty widespread, and both stock and rooted phones with different roms suffer from this little problem.
Yesterday I was forced to do a hard reset because my phone went crazy after a certain game ("destroy Gunners" free version) froze...
the fact that my Go launcher settings weren't backed up and I had to tweak it all over again, and the fact that I lost all my Gameloft games, kinda sucked, but the compensation is that the lag dissapeared.:D
It worked for me, it might work for you, although I'd think someone would have already figured it out...
Cheers!
I gotta say that although my SGS2 has wake up lag it's pretty small so I've just got used to it.
When they roll out 2.3.4 I'll see if it improves...
I thought it was common knowledge that high resolution wallpapers are what cause the lag.
None of the default wallpapers cause it.
I use widget locker anyway and there doesn't seem to be a lag with that. :D
wallpaper or lock screen? I tried using a default wallpaper but there wasn't any diff.might try a lower resolution lock screen when I get home
I'm not using TouchWiz atm so can't remember if there's an option for different home screen and lock screen wallpapers, but if there is I guess it would be the lock screen one.
I read about the startup lag before I got the phone so it was one of the first things I checked, and none of the default wallpapers seem to cause any lag for me.
