no more zumocast
smfoley1
it appears that there is no more zumocast with the JB release. Is there another app that took its place? I used it quite a bit when on the road and am now missing it
I just upgraded to the new version of JB (version 4.1.2) two nights ago and I still have the Zumocast app (I love this app and use it often as well).
I did, however, lost all my sticky notes and it looks like that app got removed. So I replaced it with Google Keep.
yes I did do a FDR after upgrading to JB. I tried to reload zumocast but it wouldnt do it. I then loked in the market for it and couldnt find it..I will check out Keep
Just went to the play store and it specifically says Zumocast is not compatible with the Bionic. However I did find Motocast which seems to be the same thing
I did an FDR a few days ago. I had no Zumocast before the FDR, and I still don't. The Google Play Store says that it is installed and not compatible with my device. I tried downloading Motocast. It downloaded and installed, but when I tried to run it, it reported that it is not compatible with this device.
Same here....wish they wouldn't take away apps without a replacement
It kinda sucks when you set up stuff to use a service and they pull the rug out from under you with zero notice.
It's probably my only real complaint with the JB update.
still havent found anything to replace zumocast...hope they fix whatever the problem is..I was using it to access my pics and other stuff on my home computer....now I have no way of doing it
That's where I'm at.
Hopefully the folks at Google are just re-branding it prior to a re-release, but them again accessing your own stuff from your own machines doesn't exactly fit in with Google's plan, so I'm not sure.
If you can get a copy of it does work on the Bionic with jelly bean. you would have to sideload it or either be rooted to do it. I'm not a hundred percent sure side loading it would work either.
Well after looking around for a zumocast replacement, I have some good news. I am using an app called polkast. Works exactly the same way as zumocast. Available for free in the android market....
