I have a rooted optinus v I have superuser permission all I have is stock android recovery so how do I flash nandroid recovery is there a link to download and what are the steps. Sorry I'm asking stupid questions but 420 was a rough day. Thanks for any help.
Check out http://androidforums.com/optimus-v-...3-1-ex-recoveryflasher-tons-new-features.html
It makes it really easy, just make sure you rename the recovery.img to vrecovery.img and you can just select the menu options and it auto puts in the adb commands you would otherwise need to type. Just follow what it says for 2. Flash Recovery
After you have a custom recovery like Clockwork you can boot to that and select backup and make a nandroid backup.
