Root no ota update notification ... ever help!
itsfrito
ok so a few weeks ago i got impatient for 2.2 to roll out and i decided to give the leaked rom a shot and in the process i couldnt get any farther then updating the radio to 2x everything else would get errors unrevoked 3 woudnt work it wouldnt even notice my phone was there i updated driver etc but thats not my question how do i downgrade the radio i cant figure it out its not rooted its S-on everything is stock but the radio and vzw tech said ill never recieve update because of this and i tried doing the manuel update with failure it just aborted someone please help
I updated yesterday evening after becoming impatient with the OTA update. I used this method for both myself and my fiance and it worked like a charm. Good luck :)
you need to get root access or you will never be able to do anything else with your phone... I dont know what you are doing wrong but unrevoked is 1 click and done onceyou have the right driver installed...
public:windows_hboot_driver_install [RootWiki]
make sure you have the right hboot driver on your computer... not the sdk driver.. set by step follow the instructions
Gonna move this to the root section, if any thinks it would be better served in the troubleshooting section please PM me.
Now that's a run-on sentence if I ever saw one.
