Can someone on 01 please let me know if their phone number shows up in SGs2
Settings
About Phone
Status
Mine does not and I think it should.
Thanks.
Oilyboy
Settings
About Phone
Status
Thanks.
Oilyboy
Ok I just found out what this is all about. In your previous phone (has to be non Android apparently) and if it is supported, you can set 'own number' or 'My profile' or some setting like that, on my Sony Ericsson C902 it is under the setting 'special numbers'. Just pop your simcard in to the phone, input your number and then put it back in your SGS2, voila, its sorted.
