Help No pinch zoom using Dolphin Mini
Motorhomer
I've just bought a Samsung Galaxy G3 and cannot get pinch zoom using Dolphin Mini. Pinch zoom works fine in Gallery and GMail.
The only place where it won't work is when browsing the web using Dolphin.
I've tried every possible setting but to no avail. Has anyone else experienced this problem?
I'm not sure which section to post this is as it may be a Dolphin problem or it could be related to the G3 so I'll post in both this and the Android Application section.
What do you mean? Go launcher is a launcher and nothing to do with browsing the web.
Perhaps you could be a bit more explicit about what you're doing and how you're doing it
I know, I'm an idiot! The problem is my browser, Dolphin Mini. It worked fine on my Samsung G2 but won't pich zoom on my G3!
Ah gotcha.
I don't use dolphin myself. If you can edit the thread title, you may bet better responses. Lots of dolphin users here :)
I havent tried Dolphin Mini tbh. You should try the full Dolphin with Dolphin Jetpack add-on. If you have a slow data connection, Opera Mini really speeds things up but isnt really a full blown browser. Same with Dolphin Mini i think
I still can't believe that no other browser is as good as dolphin mini. not even regular dolphin. it's just so much faster than anything else.
I tried them all again a few days ago and decided to stick with mini, even with no pinch to zoom.
too bad they'll never fix it.
