all of a sudden my phone went dead , pulled battery & tried recovery , plugged in power cord no light (nothing)........running 2fast kingdom xfuziionzz 4.3.2 + his v5 kernel on boost & a 32gb sd ???????????????????????????? HELP please !!!!!!!!!!!!!!!!!!!!!!!!!
I've heard of it happening before on his rom.
The problem was caused by the cwm recovery. If I remember right, it was the .7 version & was fixed in .8. I don't think there's a solution besides grabbing another phone to charge your dead battery or buy another fully charged battery. I would suggest to make sure you are running the .8 revision of cwm if & when you are able to boot back up. Your phone will remain dead until a charged battery is put into it.was there a solution ?
the battery was fully charged !!
the battery was fully charged !! & not sure what recovery i have , so i'm trying the battery charging right now ..........will let you know if that works !!!!! i'm keeping my fingers/toes,legs & anything else i can cross ............................thank you all 4 the info , did'nt think it was the rom but was'nt sure what the cause is !!!!!
tried the full battery , no luck , did not do any mods or updates ,apps , nothing out of the ordinary .... just called HTC & have 2 ship 2 them , does any1 know if they will say anything about being unlocked/rooted .?
i know its not a charging prob. , i was able 2 use another phone 2 charge my batt. & my kernel was set at 1920/368 ,,,,, so I don't think it had anything 2 do with your rom or kernel , but i am a noob so i'm can't be 1hundred % sure , but i did not do anything other than try 2 open FB .... i'm thinking its hardware (atleast i'm hoping) , that is why i did not give you a shout out (2fast) , like i have said b4 your stuff rocks (i will b reinstalling your rom & kernel again ) so if & when you can please hook me up with the new recovery & whatever updating you have done 2 xfuziion 4.3.2 / daily use of cm10 (stable)..........thank you every1 who has responded 2 this thread ....
