Help No ringtone or audio on phone today
TXBamanut
My wife's Captivate stopped ringing today...
No ringtones, no notifications, no mp3s, no sound on videos...calls show up and you can answer, talk and be heard, just no audio other than that.
Media volume up full.
Ringer volume up full.
Notification volume up full.
System volume up full.
Not on silent.
Not on vibrate.
Haven't tried it with a bluetooth headset because she doesn't use one.
Hasn't dropped it...nothing like that. Any ideas?
God help me...I'm on technical support. I have CLEARLY repeated my problem 4 times...FOR TWO FREAKIN' SUPPORT TECHNICIANS...they still don't understand the problem.
Please hand me a knife...jk
the only thing i would try is a battery pull but its probably something internal with the phone.
and i know about the tech support, i told them my phone wouldnt turn on atleast 5 times and they said "is your battery charged". no saleem im wasting my time calling you because my battery is dead. i hate tech support
over half an hour on the phone...and they hung up on me.
GAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Happened to my husband's captivate today. Found another post that described the external speaker working loose, the repair shown there fixed it. We hadn't dropped his phone either, but it had been pulled in and out of a case a lot yesterday.
"Remove the battery cover, press firmly on the external speaker with your thumb, replace the battery cover. The external speaker is on the upper right above the battery, just under the vented area on the back cover." (It said power off, we didn't.)
Just wanted to let anyone who has this same problem to know that I did exactly what the person 2 posts above me described by removing the battery cover, pressing on the speaker and BAM!! problem solved. Appreciate the advice slconline.
MY PHONE HAS NOT HAD ANY SOUND ALL DAY AND I WAS READY TO GET A NEW PHONE... SO TIRED OF THE PROBLEMS I'VE HAD.
This solution worked for me... thank you thank you thank you!
Was sick of chock holding my phone just to get the sound on for a second or two a then found this thread and it gave me some ambition to investigate the issue further found a tutorial on replacing the speaker which had great instructions with pics after makeing a tool to assist I decided to attempt the dismantling of the phone. So basically long story short there is a contact between the speaker and the phones motherboard that was not making full contatct if u can picture this < as being the contact I just over bent it so that it would defiantly make contact . So far I have been playing music for two hours and it has not gone off yet so for now the issue is resolved I hope this helps someone. If you want the link to the speaker replacement tutorial I will be happy to do so just email me mrblueomega@gmail.com
