You have your phone set to time out over a long period of time. Also, your setting for the power button to lock the phone is disabled.
IOW, when you power off your phone, it is not locked, b/c of the long lock timeout and b/c the power button is not set to lock the phone. I'm betting hat you're pressing the power button, and as soon as the screen goes off pressing it again to wake it up and it has no lock screen. This is b/c of these settings.
I'm making a Nandroid backup right now so I cannot tell you precisely where each is (IOW, forgive me if this is incorrect), but the power button setting (I think) is in settings --> Developer options. The phone lock time out is under Settings --> Display.
If you set the power button setting, every time you press the power button when the screen it on it will lock the phone.
If you adjust the screen lock timeout, it will lock sooner without you doing anything. IOW, 30 seconds means that 30 seconds after it detects no activity the phone will lock automatically.
HTH
