No signal inside
Titan1
LM-K500MM
I live in a mobile home. My Provider is Metro PCS, using the T-mobile network. My outside signal is decent, but when I go inside the mobile home I lose all signal.. How can I defeat this issue?
Both. My cell phone receives internet and telephone calls outside the home. The problem occurs because my trailer is like a faraday cage. How can I bring the signal inside my home for both cell phone use and internet use on my cell phone?
hmmmm you can get things like a cell booster like this:
https://shop.weboost.com/boosters/?...kJjTCdVI-knSuZRijYOx3Q81u6EkNW94aAszcEALw_wcB
maybe contact your carrier as well, they may having something similar.
not sure on internet other then getting wifi installed inside.
I will check out the cell booster, my carrier offered no help at all. I live in a VERY rural location of southeast Ohio, hills and empty woodland. Internet options are almost non-existent and of unacceptably poor quality. What do I need to do, to setup a wi-fi system between the inside and outside of my home?
you might want to look into getting a mobile hotspot. not sure how that would work in a mobile home signal strength wise. you might want to head on out to your carrier's store or someplace like Best Buy to do your research.
I don't have problem with signal strength or hotspot outside the home, I lose signal from the interference from metal siding and roofing inside the home. I get 15 free Gigs with my metro pcs account.
