Root No SIM card
I replaced the digitizer in my Sensation with a T-Mobile brand (previously Cincinnati Bell), and now my phone keeps telling there's no SIM card. The new digitizer works but I can't get it to recognize the SIM card. I've seen others on the internet with the same issue but I haven't seen a resolution. I've S-Off, rooted, and SIM unlocked with the same issue. Does anyone have a fix?
Have you tried SuperCID? That might do it for you.
if he flashed the available DIAG file,then it superCIDed in theprocess.
if not,then superCID would be worth a try,but generally has nothing to do with the booted device seeing a sim card,it simply determined wich RUUs you are allowed to flash.
are you 100% sure this sim is good? can you verify it in anotehr cin bell phone?
