Root No SMS After WiMax Fix?
I recently updated to the 10.1 Angry Bean ROM and followed all the directions. Everything worked exceptionally well, until I started getting the "low storage space" issue (due to WiMax logs). I searched around on the forums and found the "Fix" which is to flash a certain zip file to clear the log files.
I downloaded and flashed that file. My low storage space issues went away, but I now cannot receive SMS messages. I can send without any issues - I can send and receive phone calls, but no SMS messages get sent through.
Anyone have any ideas? I read that I should update my user profile and prl, but those options no longer appear in the settings in the Angry Bean ROM.
Thanks for the help
Try flashing a stock based rom or nandroid, such as Harmonia, after updating you can then try the new rom again and see if it resolved the issue.
OB
