Help No sound for notifications or alarms
votto
My phone hasn't been making sounds for alarms or notifications. When I select ringtones in the "sounds" settings, they don't even play there. On the volume levels screen, when you change the level, Ringtone and Music and Video play a little bit to show you what the new volume is. Again, alarms and notifications are silent.
The only time it almost makes a sound is when I select a sound on the picker screen, wait a few moments, and then back out. It makes a quick sound like it's starting to make the sound but gets cut off.
I tried getting an application to customize ringtones (SMS Sounds) which worked on my old phone. The ringtones will play in-app but still not when I get a text. And that obviously does nothing for my alarms.
Vibrate works. My sound profile is set to normal (not silent) and I have the sound for both turned all the way up. Help, please?
