Help No sounds/vibrate
imnotmikal
Android Expert
Just recently, my phone has stopped vibrating and playing notification sounds of any sort.
I've missed numerous calls/texts/emails and it's really bothering me...
I've tried restarting, that did nothing, and I've tried a battery pull.
My sound is all the way up, and vibrate is enabled....
Any ideas?
I wish I was eligible for an upgrade, this piece of trash would be long gone.
Is other sound working?? I have the motor that vibrates go out on my old phone but i doubt you could have that AND the speaker go out at the same time. Does do you ever plug in headphones or other cords? Sometimes the sensor or whatever can malfunction and it thinks you have headphones pluggin in when they arent. If you are rooted try wiping cache/dalvik cache and if it still doesnt work restore a nandroid
u dont need an upgrade for a new phone you can buy one on ebay and activate it for free and the best part is you keep your #
I don't plan on paying $600 just to get a new phone.
When I upgrade, I'm getting a better Android, not some shitty $10 ebay phone.
Also, the problems seems to have fixed itself. It's still more than done with this phone. Once February of next year rolls around, it's outta here.
