Ive noticed there is no longer a sync icon at the top of the pull down page after the latest 4.1.2 JB update. Is there no longer any way to toggle sync on/off.
That would be nice, but I dont see any way to change it in settings
This is what another person posted in the Update 4.1.2 thread:
http://androidforums.com/5433417-post13.html
Hmmm...... I dont have a "notification panel" under display settings. Is anyone else missing the Sync option on the pull-down page after the 4.1.2 upgrade? If not I must be missing something somewhere else? Anyone?
Just noticed you're on ATT. Do you have the ATT version with 4.1.2 or the International?
Can anyone that has the newest 4.1.2 on ATT verify they still have the sync icon on the pull down page or either have a Notification Panel in the Display Settings where Icons can be added or removed? Am I the only one that is seeing this?
Drex.... thanks for your reply. I thought it was strange they would remove the option to disable it. Maybe there is a way with Root, but I havent made the move yet..... maybe soon.
On the 'other' site Stadman posted "I could not find a stock solution for the verizon note 2. I ended up adding a beautiful widget for that switch and it worked again."
So that is an option I guess...... I just dont like my phone syncing continuously when for me there is no need. Maybe it will be changed in the future.
Thanks for your help
C~~~
Widgetsoid is my notification toggle of choice. That's free, if you want to try it out (although, I should say that it's worth donating to the developer. He's a one man show and is very responsive, even if it takes him some time to reply to all emails).
I created a Notification toggle using Widgetsoid on my Sprint Note 2, since that one doesn't have the ability to change the OEM toggles.
You're right Drex...... that is a cool App and it did just what I needed. It did take me some time to figure it out but once I did it is very powerful and has a lot of options. I plan on donating. Thanks again
Do you mean create a widget to go on a "page" instead of in the notification area........ I did that by mistake at first. If that is what you are referring to I will try to remember how I did it and post.
Im not sure if this is what you want but under the list of toggles there is one called application and when you click on it, instead of just adding it, it opens a list of applications....... is that what you need?
There is also a "Custom" that you can assign an .exe to. Not sure if either of those are what you are talking about tho
