sorry if this is a silly question i have no usd de bug check box under gear info ?
graceful77 Lurker Nov 27, 2013 5 3 perth australia Nov 30, 2013 #1 Nov 30, 2013 Add bookmark #1 sorry if this is a silly question i have no usd de bug check box under gear info ?
ocnbrze DON'T PANIC!!!!!!!!! VIP Member May 13, 2010 40,476 1 33,614 Los Angeles Dec 1, 2013 #2 Dec 1, 2013 Add bookmark #2 graceful77 said: sorry if this is a silly question i have no usd de bug check box under gear info ? Click to expand... no such thing as a silly question.....the only ting silly would have been if you did not ask it actually that is a very interesting question......as i have it on mine. which software version do you have? edit: welcome to AF!!!!!!!!!!! Upvote 0
graceful77 Lurker Thread starter Nov 27, 2013 5 3 perth australia Dec 1, 2013 #3 Dec 1, 2013 Add bookmark #3 thanks for the welcome mate. finding this forum very helpful. software is v700xxuamk7. for anyone else who has this problem. i found.over on xda's forum. you need to tap on software version about 10 times then it will show de bug option Reactions: KOLIO and ocnbrze Upvote 0
ocnbrze DON'T PANIC!!!!!!!!! VIP Member May 13, 2010 40,476 1 33,614 Los Angeles Dec 1, 2013 #4 Dec 1, 2013 Add bookmark #4 graceful77 said: thanks for the welcome mate. finding this forum very helpful. software is v700xxuamk7. for anyone else who has this problem. i found.over on xda's forum. you need to tap on software version about 10 times then it will show de bug option Click to expand... that is odd.....thanx for posting the solution. Upvote 0
K KOLIO Guest Dec 2, 2013 #5 Dec 2, 2013 Add bookmark #5 ocnbrze said: that is odd.....thanx for posting the solution. Click to expand... I've had to do this on phones,but,I honestly can't remember if I had to do it on the GEAR or not. Was GOOGLING for this exact item,but,nothing turned up. As the OP did,XDA-DEVELOPERS is always a good go-to when all else fails. Reactions: graceful77 and ocnbrze Upvote 0
S sulkis Lurker Dec 3, 2013 1 0 Dec 3, 2013 #6 Dec 3, 2013 Add bookmark #6 hello, I do not have that choice in option. What shuold I do? thanks Upvote 0
graceful77 Lurker Thread starter Nov 27, 2013 5 3 perth australia Dec 3, 2013 #7 Dec 3, 2013 Add bookmark #7 open gear info. and tap software version around 10 times to enable developer options and de bug will appear Reactions: ocnbrze Upvote 0
