no vibrate for SMS
I just joined the Droid Family and Im having problems with vibrate mode. If I set it to vibrate, It does not vibrate for sms messages. Any ideas as to how I can get it to vibrate for SMS's? Thank you!
Load up your messaging, hit the menu button, goto settings and scroll down till you see the vibrate option (at the bottom). check it off and you should be good. It should work after that.:)
