Help No vibration
justin4236
OK my phone overheated so I left it with the battery out for an hour turned it on, but now it won't vibrate at all? What could have happened?
Sent from my N860 using Tapatalk 2
First thing to do would be rule out hardware failure. Use the ## codes at the link below to test your vibrate function. If it works then hardware is working properly and you have a software/settings issue.
ZTE Warp ## codes
Thanks, I guess its hardware. When I do the vibration and LED test it doesn't vibrate. Oh well, I can live without it.
Lol, just a tip to everyone. Don't leave your phone charging all night while the CPU is set at its max. These things can happen:)
