Help No Voicemail Icon?
WACOMalt
So my question is a bit odd... After some tweaks I found myself having to SBF back to 2.1 (from FlyX Final) and then upgrade back etc etc. Anyways, I am back at FlyX final, and deleted the default voicemail shortcut on my desktop.
If I remember correctly, I used to be able to make a shortcut to a voicemail app in my drawer, but now that isnt there.
Also at one point I did a bettercut shortcut to one of the voicemail activites. This worked perfectly. However now no voicemail intents are listed under activites. I cant do a direct dial shortcut from bettercut because voicemail contact isnt listed, though it is in my contacts.
So, how do I get a voicemail icon? one that will either direct call, or show the screen with the unread count, and button to call.
