Root No Voicemail Notification
jreink01
Android Expert
I was on midnight's rom (1.3.9) a few days ago and no problems with it, the voicemail app worked perfectly.. I decided to try g 60's HTCCM10. With this rom, I had no voicemail notification (app). I posted on the htccm10 thread and was suggested I go to this link (http://androidforums.com/evo-v-4g-all-things-root/671359-get-vvm-working-aosp-ect.html) to download a voicemail file to see if it works. It did not work. There also was a voicemail file to remove the other installed voicemail file. I downloaded that and restored midnight's 1.3.9 rom, then I downloaded the newest version of midnight at the time (1.4.4). I cleared the caches and installed the newest version. Now, on the newest version, the voicemail notification is not working. I am getting that irritating text message I got on cm10 that says that I have a message, call #### number. I do have the voicemail app (the same one I had when I was on 1.3.9 and worked perfectly), but for some reason it does not notify me in the status bar and when I press the voicemail app, the message is not there. I have to dial my number to retrieve the message. Anyone have any suggestions on what I can do to get my voicemail app working properly again?? Did I screw something up when I installed that voicemail file when I was on cm10?? Please help.
Probably more then just wipe caches. Do a full wipe. Clean install midnight
