Help No WebOS
Sorry for the Noob question...Just realized I installed my unlocked TP on another computer and I don't have Palm, inc folder needed for the CM9 install.
So, do I have any options to complete the process?
CM9 works best when you wipe data (clean slate -- no apps), so no big deal, but a little riskier.
Copy all the files to your TP, boot into recovery and:
Make sure you can find your files, then :D
Backups menu: backup rom
Mounts menu: Format data, format cache
Advanced menu: wipe Dalvik cache
Flash your rom
reboot
set up wireless
boot into recovery again, flash gApps, gApps fixer
reboot
sign into Market.
Noob city over here....lol.
Okay...for some reason when I boot into recovery, there is no CM9 recovery option. Only a WebOS recovery. I'm trying to flash the apps.zip file Any thoughts?
Did you flash a CWM file when you installed CM7?
You should have flashed CM7, moboot, gApps and CWM.
When you press the power button, you should have an option to boot into CWM recovery.
Just checked...no I didn't. :mad: Okay...so what are my options at this point? Can I just drop CMD in my cminstaller folder? Or even better can I just start over?
Sorry, you can't do a thing without installing Novacom on something.
Then you can simply copy CWM, CM9, gApps, gApps fixer to your cminstall folder and install it. Then I'd boot into recovery and format data, when you install Google apps/fixer.
Thanks Buddy! I actually found a link for Novacom! It's a stand alone installer that worked like a charm! I have ICS installed, I just forgot to copy CMD over.
