No wifi or cellular widgets on home screen
I lost wifi, cellular and bluetooth widgets on home screen. I still have all three working correctly. I would like to be able to see them on my home screen and not have to pull down my settings menu to check connectivity. Does someone have an answer.
Download third party apps that allows you to add those widgets
On your Home screen long-press on any blank area (not on an already existing icon) and tap on the 'Widgets' icon that's on the bottom of the resulting screen. Scroll down to 'Settings shortcut', drag and drop on your Home screen, and another contextual listing of your Settings menu will pop up. Select 'Wi-Fi' and that will create a Wi-Fi widget on your Home screen. Do the same process for Bluetooth, etc.
Just curious what you mean by lost? Did you have them and they disappeared?
I meant on the right hand side of the phone where the battery percentage is. I guess that's actually called the status bar. I had lte, wifi and bluetooth icons there when I got my phone. After I finished setting up the phone the way i wanted they disappeared. That included changing to a different wallpaper.
