Root No WiFi Teather
mj1975ma
My connect phone is rooted . But I can't USB or WiFi teather . Any answers to this one ? I used Clockworkmod to root phone. For LG-MS840 Connect.
Ok so I'm using the app that was sugested but still can't connect . It tells me that DNS sever is not responding. At one time it showed connected to network globe then flashed off . Then told me t-moble does not allow hotspot. WTf I don't even have T-moble . Help please .
I don't usually tether, but I did set it up after rooting just for the hell of it. I have Open Garden from the Play Store. I had to set the device as an Optimus S too. Then I had to download a user agent plug-in for my laptop's browser (I was tethering to the laptop &I use Firefox on it). After installing the plug-in for Firefox onto the laptop I had to manually enter the user agent from my phone into the plug - in. A quick Google search on my phone led me to a website that gave me the user agent to put in on the laptop. I think that was all I had to do to get it to work, but it's mobile web, not the regular internet.
I moved this thread over to the All Things Root forum so the root users can help out. :)
A good alternative for this is Foxfi. No tweaking, I use it and it just works. ;)
depending on ur location you probably need to use a user agent string. look it up you need an android user agent string
