I am at my wits end and hopefully one of you can help.
The phone in question is is the AT&T Galaxy S2 SGH i777. It was running a jellybean ROM and there were problems with the GPS and google maps not working at all about four months ago. Not sure what happened. I went through the usual process of putting a ROM on the SD card, wiping cache/davlik and installing, then installing the gapp.apk for that rom. Everything was fine. Except wireless. Wireless would not connect. Just wouldn't do it. Googled forever, found no real solution. Thinking it was the rom I reinstalled. Wash rinse repeat. Same issue. Thinking it was a bad rom I proceeded to go through about six more roms. Same issue. Four hours later I resolved to unroot, take it back to stock. Took it back to stop with no issues. Wireless worked just fine. Everything was great. Rooted it again with the stock gingerbread. Wireless worked fine. Made a backup of the rom and was feeling lucky so I installed the Carbon ROM from the Sept 29th post on galaxys2root.com (I don't know if you guys allow linking here) and the gapps from that post. I boot. Everything is looking fine....yet the wireless doesn't work. This has been consistent across every rom I installed. I am quitting for the night.
It is currently running android 4.3, kernel version 3.064-CM-gbc8f4c9 (if that helps). The phone service is fine and makes/receives calls/texts just fine. No other blaring issues. Worth pointing out: all roms in question came from galaxys2roms.com under the section for the AT&T i777 s2, so they should be compatible. Followed all directions/video ect.
I had this phone for years (girlfriend has it now) and Rom'd it many times with next to no issues, especially not with wireless. I don't understand why it was working fine on a JB rom and trying to change rom suddenly screwed the wireless.
I am literally at my wits end and it's probably the result of me being an idiot somehow and missing something. Can anyone suggest a fix?
God bless in advance.
